Big one or small one?Looking for suggestions on a good servo for an arrma kraton 8s?
60 mm steering servo i always recommend the 75 kg rovan servo..cheep and great value for money,check this video..Looking for suggestions on a good servo for an arrma kraton 8s?
In the end of video i show the power of that servo, i use it on all my 1/5 scale builts, never had a problem with them...Looking for suggestions on a good servo for an arrma kraton 8s?
I will check them out I have everything else except the servo.Big one or small one?
I have the exb idk if it already comes w the servo saver or not or the mount. I might have to get it all newS9120.
https://www.spektrumrc.com/product/...ess-metal-gear-surface-servo/SPMSS9120BL.html
The measurements are so critical to re use the servo saver.
This servo works great.
Only 60$ for the servo...I will check them out I have everything else except the servo.
Only 60$ for the servoI will check them out I have everything else except the servo.
Install the servo saver on the new servo...I will check them out I have everything else except the servo.
In order to use the 845 he needs to modify the tray. Is not a bolt on.i use the hitec 845wd works great.
