enzo3856
I have a HPI rf-11 receiver and I am having some issues with it, hoping someone has experience
Just moved the receiver from one car into another, and had to reverse the throttle servo... the problem is the built in "fail safe" of the receiver
On the previous car I programmed it to slam the brakes if it lost signal (also have a kill switch installed)
Anyways, on the new car I am having issues programming this fail safe... as the channel was reversed, the RX goes full throttle if the TX is turned off... I managed somehow to disable the failsafe, holding the setup button while I powered on... so now it just does nothing if the TX fails, it stays in whatever condition is was in
Manual says to hold setup button and light will blink... it is not doing anything... what am I missing here?
This is a bit of a concern since I am including this on a truck i am selling, and i am not including a kill switch.... should I care ?
