Here is my new FG Leopard 2
The car is rather good, but to make it more reliable the car need to be upgraded. So lets start
The first thing that was upgraded is the radiobox
MCD radiobox installed. Battery and all other electronics are sealed now.
Alloy diff tube
Alloy FG gear carrier and steel cat5mfg gear
You can also see that the servo moved closer to the motor, because with long linkages the controlling of brakes and throttle is very inaccurate.
The exhaust it also changed. The std exhaust took away power from the motor because the exhaust tube was installed right in to the muffler and the exhaust had less output diameter
Fuel tank vent
With the standard one the motor worked very bad.
Hpi wheel adapters.
The standart wheels are too bad for winter use and small for our track.
First tests...
...showed that the suspension is too hard and the front ground clearance is too short. The front and rear shock are the same length, but the front suspension is not fully work, because the front lower arms can not drop lower, because of the chassis
Chassis mod:
So now the front shock travel is fully used :lol:
But there is another problem- steering turnbuckles can not work lower, because of the stupid 4wd conversion diff housing. So i cut it:
And now front suspension and steering work ok
And the ground clearance is good
(i have no clean dirt busters, so the photo is with tarmac wheels, but they are the same diameter.
Other ugrades:
All bearings fitted on ca-glue, servo saver modified (no free play (up-down)), fuel tank support changed to old (FG marder) support (the fuel tank is now lower)
This is not all upgrades, i will male some mods and post here some new pics in future
There will be some serious upgrades, such is front suspension support brace, because the chassis flexes and can be bend in front
Alloy diff tube
Fuel tank vent
Hpi wheel adapters.
First tests...
Chassis mod:
Other ugrades:
