Go Back   Large Scale Forums > Large Scale R/C > FG Marder and FG Baja Buggies
Post Reply
Thread Tools
Old 08-26-2010, 01:21 PM   #226
Rossco
BAJA BASHER !
Rossco's Avatar
Trader Feedback: (0)
Default
That's coz your'e a dirty bugger
__________________
Rossco.
I HATE NITRO'S !!
Rossco is online now   Reply
Untitled Document
Old 08-27-2010, 01:04 AM   #227
sperera
sperera's Avatar
Trader Feedback: (1)
Default
LOL, cant argue with that.
put a new engine mount on last night and put engine and radio tray back in. all i get left now is the pipe and she's ready for a floggin
sperera is offline   Reply
Untitled Document
Old 08-30-2010, 01:02 AM   #228
sperera
sperera's Avatar
Default
looks like I lost some exhaust bolts, anyone know the spec I need so i can get some from a bolt shop?
Untitled Document
Old 09-02-2010, 01:10 AM   #229
sperera
sperera's Avatar
Default
started the FG for first time in a couple of weeks last night after complete clean (had it down to chassis) and the idle was crazy low straight away, i did clean the air filter which was quite dirty so not sure if this would have affected it.
adjusted the LS to get idle right and it sounded good through rev range but a little curious as to why it tune would have changed like that.
Untitled Document
Old 09-03-2010, 02:34 AM   #230
sperera
sperera's Avatar
Default
ok i think ive definetly got some sort of engine problem. started the fg again last night, havent touched the needles since yeasterday and idle was very high. turned the needle out and revs dropped for maybe 10 seconds and then instantly stalled, no drop of revs nothing.
couldnt get it going again so changed the plug and it started first pull, idled nice, too dark to take it for a run so just reved it on stand for a bit.
any ideas? should I strip it down or take it for a good run first?
Untitled Document
Old 09-06-2010, 06:30 AM   #231
sperera
sperera's Avatar
Default
took it for one last run today to make sure there is def. a prob and now i have no doubt something's wrong. feels like its got no compression, performance is definelty not where it used to be and its not responding very well to needle adjustments.
going to put a new ring in it and see how we go. might put up some pics of the the piston and bore and get opinions if I should be changing that as well.
Untitled Document
Old Yesterday, 01:03 AM   #232
sperera
sperera's Avatar
Default
[B]removed the engine last night and took the head off, havent got any pics yet but had a close look under some very bright down lights in the house.
piston is unmarked, besides some carbon build up on top of piston which I think is normal. not even the slightest of scratches on the sides. the bore is also excellent, one of the faintest marks inside, wouldnt even call it a scratch but otherwise perfect.
based on this im going to replace the ring and try again. also notice that my clutch spring had snapped so just ordered another one, dicided to try a red HPI one instead of the stock blue fg one that came with it, see if I can get it going harder off the line. so hopefully tommorow I get my alloy engine mounts, exhaust gaskets, clutch spring and some other small items.
let the fun begin
Untitled Document
Old Today, 04:44 AM   #233
sperera
sperera's Avatar
Default
got all my bits today, alloy engine mounts, clutch spring, piston ring, gaskets etc.
stoopid me ordered a large 2wd alloy engine mount which ofcourse isnt compatible with my 4WD FG so i need to sell one now as ive already had the bearing pressed.
CRAP!
Untitled Document
Post Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Video Collection - Large Scale RC's Bigger the Better General Large Scale RC 98 08-25-2010 07:06 AM
Baja clone experience naynay12 King Motors and other baja Clones 9 08-16-2010 10:23 AM
HPI Baja 5T RTR!! Pre-Launch Orders!! guerrilla_rc HPI Baja 0 10-19-2008 11:55 AM
Its a 5t! maxair45 HPI Baja 12 09-26-2008 01:26 AM
Baja goes 120 Miles through the desert! ScooterTrash HPI Baja 19 03-27-2007 03:57 AM
Copyright © 2008-2009 LargeScaleForums, All Rights Reserved
Powered by vBulletin®, Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Our Community
Latest Forums Topics
About Large Scale Forums
Need Help?
