Go Back   Large Scale Forums > Large Scale R/C Forums > King Motor Baja
Exhaust cracked head from crash help please
Discussion in King Motor Baja forum, started by jbraswell47.
Post Reply
Thread Tools
Unread 03-18-2012, 07:40 AM   #1
jbraswell47
Junior Member
Trader Feedback: (0)
I have a ddm pipe, took a tumble the other day an it cracked a exhaust bolt from head, but didnt crack to piston still ran but of course it made a funny sound i ordered a rebuilt kit, but need help on how to prevent this in the near future, like an coupling?
jbraswell47 is offline   Reply
Unread 03-18-2012, 12:47 PM   #2
chitown joe
chitown joe's Avatar
Trader Feedback: (2)
heres a thought, J-B weld, i used it on my nitro exhaust when i would crack the stingers off or stripped out the threads,
they use it on 1/1 engines so i dont see why you cant use it on these lil' guys,
have to try it out when if and when i pop some head threads or crack something
chitown joe is offline   Reply
Unread 03-18-2012, 02:04 PM   #3
mickey
mickey's Avatar
im guessing you have a dominator v1 pipe. yes cut it around an inch away from the head and use a silicone or rubber connector to prevent this from happening again.
mickey is offline   Reply
The Following User Says Thank You to mickey For This Useful Post:
jbraswell47 (03-19-2012)
Unread 03-18-2012, 04:21 PM   #4
rcspeedmart
LSF Plus Member
rcspeedmart's Avatar
Send a message via Skype™ to rcspeedmart
Quote:
+1 to allow room for chassis to flex.
rcspeedmart is offline   Reply
Unread 03-18-2012, 04:36 PM   #5
Syphon
Been there: does it look something like this
This is kinda what you want it to look like when it's done, I didn't end up cutting mine because I wanted a more protected pipe but I have read others had good luck doing it.
http://www.davesmotors.com/s.nl/c.88...t.A/id.6447/.f
Syphon is offline   Reply
The Following User Says Thank You to Syphon For This Useful Post:
Unread 03-18-2012, 04:46 PM   #6
voo2doo
Moderator
voo2doo's Avatar
Trader Feedback: (5)
There is a lad on here called Jackobyte and he done this two or three times.Another lad called Pablo came up with a fix that Mickey said.
Cut about an inch from the manifold and take a 5 mm ring out of the pipe as well then you will need some Samco or similar silicone piping to use as a joint,jubilee clip the two together and bingo...jobs a guddun.
J
voo2doo is offline   Reply
The Following User Says Thank You to voo2doo For This Useful Post:
Unread 03-18-2012, 04:57 PM   #7
voo2doo
Moderator
voo2doo's Avatar
Ah,found it.Have a look at this ,it might help you.This is what most do as a standard mod on a V1 now.
http://www.largescaleforums.com/show...ht=exhaust+mod
J.
Unread 03-18-2012, 11:28 PM   #8
jbraswell47
Junior Member
thanks this what i will do.
Unread 03-19-2012, 12:01 AM   #9
jbraswell47
Junior Member
yes it is but the broke piece came off all the way.
Post Reply
Share This Post
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Head Bolts! tizdaz Large Scale RC Engines and Exhaust 13 04-01-2013 05:39 AM
ported head damage pacman696 Large Scale RC Engines and Exhaust 7 05-31-2011 05:51 PM
HallowPoint RC Exhaust Stud kit review. Timmahh Large Scale RC Engines and Exhaust 1 04-26-2010 07:44 PM
Race Ported G260rc Head Compared To The Stock G260rc Head benckie Large Scale RC Engines and Exhaust 8 06-15-2009 02:20 AM
Zenoah G270rc Head Compared The Zenoah G260rc Head benckie Large Scale RC Engines and Exhaust 4 06-01-2009 06:57 PM
Copyright © 2008-2011 LargeScaleForums, All Rights Reserved
Powered by vBulletin®, Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Our Community
Latest Forums Topics
About Large Scale Forums
Need Help?
