Go Back   Large Scale Forums > Large Scale R/C Forums > HPI Baja
Radio Transmitter Range
Discussion in HPI Baja forum, started by Tippy.
Post Reply
Thread Tools
Old 03-10-2009, 09:09 PM   #1
Tippy
Junior Member
Trader Feedback: (0)
I have HOBAO remote control for my Baja 5b ss. It is 27mhz pistol type transmitter. The maximum range in terms of distance is only 30metres to 50metres. I was told the range would be 250metres. Anyone faced such a problem? what could it be that is restricting the performance?
Tippy is offline   Reply
Old 03-10-2009, 11:36 PM   #2
Timmahh
Bajastafarian Madnes
Timmahh's Avatar
Trader Feedback: (6)
Send a message via Yahoo to Timmahh
AM or FM radio?
Habao would be part of Jammin so owned by Ofna, so likely a rebaged hitec agressor or similar radio.
on a gas rc, i strongly recommend a 2.4 radio 3 channel radio, with a remote kill switch/failsafe unit.
__________________
I once thought I was wrong, but I was sadly mistaken!
Timmahh is offline   Reply
Old 03-11-2009, 12:27 AM   #3
mooman007uk
mooman007uk's Avatar
yeah the 27mhz get interference from the gassers ignition system...probably why it wont go more than 30m
mooman007uk is offline   Reply
Old 03-12-2009, 05:22 PM   #4
Tippy
Junior Member
Thank you, oops I forgot to mention it is a AM transmitter
Old 03-12-2009, 06:36 PM   #5
Bigger the Better
LSF Plus Member
Bigger the Better's Avatar
Trader Feedback: (3)
Don't use the AM one. You will get bad interference. I would also recommend using the 2.4ghz radios. A little more but way better.
__________________
If I had a million dollars I'd own them all.
Bigger the Better is offline   Reply
Old 03-13-2009, 02:18 AM   #6
dirby
get a futaba 3pm 2.4 gig.
about 190.
this will take care of all your eangr problems.
i got over 1100 feet range with mine.
dirby is offline   Reply
Old 03-13-2009, 04:58 AM   #7
Timmahh
Timmahh's Avatar
ever listen to an am radio during a thunderstorm? thats the same type of interferance your coil and plug will give your am radio system.
2.4 is the smartest way forward as even FM Synths have glitching occasionally.
__________________
Old 03-13-2009, 09:41 PM   #8
Trip
Trip's Avatar
Good point Timm... I had a 27 AM that used to flip out whenever a nextel would ring...
Trip is offline   Reply
Old 03-13-2009, 10:51 PM   #9
Bigger the Better
LSF Plus Member
I can't even imagine what a nextel could do to an AM radio.
Who needs a ringer with nextel just watch your screen and listen to your speekers. Man what's it doing to our heads?
__________________
Old 03-13-2009, 11:49 PM   #10
Trip
Trip's Avatar
That's why I switched to a Virgin! lol Oh wait, that didn't come out right
Old 03-21-2009, 06:59 PM   #11
MrZ2
Junior Member
so this may be a dumb question and I am sure once I read the answer I will wish to delete this post but what good is a kill switch once you are out of range? Does it have some sort of heartbeat signal that defaults to off if comms go out?
MrZ2 is offline   Reply
Old 03-21-2009, 10:23 PM   #12
Timmahh
Timmahh's Avatar
the PBkill switch is a good one, when setup with your onboard failsafe on chnl 3, the motor will shut off if you go out of range, lose rx power, lose tx power, ect...
__________________
Post Reply
Share This Post
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
help!! radio carnage with pick!! kryptonite5b Large Scale RC Electronics 8 09-05-2008 05:02 PM
In the market for a new radio for my MT. cycleoneoff FG Monster Truck / Beetle 13 09-01-2008 12:42 PM
radio set up???? pics please justaf_IREMAN FG Monster Truck / Beetle 2 08-22-2008 10:44 PM
Copyright © 2008-2011 LargeScaleForums, All Rights Reserved
Powered by vBulletin®, Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Our Community
Latest Forums Topics
About Large Scale Forums
Need Help?
