Go Back   Large Scale Forums > Large Scale R/C > Large Scale RC Engines and Exhaust
Need tio make 25:1 Oil Mix
Discussion in Large Scale RC Engines and Exhaust forum, started by New2FG.
Post Reply
Thread Tools
Old 05-01-2010, 07:16 PM   #1
New2FG
Trader Feedback: (0)
I bought a 3.2 oz. bottle of synthetic oil and it says a gallon makes 40:1..I'm no mathematician..so how much gas do I need to make 25:1? Thanks.
New2FG is offline   Reply
Old 05-01-2010, 08:12 PM   #2
dwarfy
dwarfy's Avatar
Trader Feedback: (1)
I can only work it out in metric so here goes........
1 US fl oz = 30ml x 3.2 (for your bottle) = 96ml
96 x 25 (25:1 ratio) = 2400ml or 2.4L of gas
Converting back to US gallons........
1L = 0.26 US gallons x 2.4L = 0.624 gallons of fuel for your bottle
Hope this helps
dwarfy is offline   Reply
Old 05-01-2010, 08:14 PM   #3
atom3624
atom3624's Avatar
Get a 2 stroke mixing bottle off Ebay, or perhaps a local garage or similar.
They indicate a 1 litre fill point, and then give several options of how much oil to add to give 25:1, 32:1, 40:1 etc. Cheap as well.
atom3624 is offline   Reply
Old 05-01-2010, 09:12 PM   #4
Bigger the Better
LSF Plus Member
Bigger the Better's Avatar
Trader Feedback: (3)
http://www.csgnetwork.com/oilfuelcalc.html
__________________
If I had a million dollars I'd own them all.
Bigger the Better is offline   Reply
Old 05-02-2010, 12:08 AM   #5
New2FG
Ok thanks guys..Atom my friend got one of those bottles with his King Motors..I definitely gotta get one.
Old 05-02-2010, 02:23 AM   #6
Timmahh
Bajastafarian Madnes
Timmahh's Avatar
Trader Feedback: (6)
Send a message via Yahoo to Timmahh
you need in US measurements 5.2 oz of oil for one US gallon to make 25:1 ratio
4.2 oz of oil would make 32:1 ratio in one US gallon
and 3.2 oz of oil would make 40:1 in one US gallon
__________________
I once thought I was wrong, but I was sadly mistaken!
Timmahh is offline   Reply
Old 05-02-2010, 04:00 AM   #7
pipeous
pipeous's Avatar
Send a message via MSN to pipeous
I do the no brainer... 100ml of oil to 2.5 litres of gas. 2.5 litres is 2500 ml
pipeous is offline   Reply
Old 05-02-2010, 05:14 PM   #8
CSR260
CSR260's Avatar
Trader Feedback: (2)
correct me if Iam wrong? I use 4 liters of petrol and 160ml of oil and does that make a 25:1 mix? Ive been using it method for 2 years and Ive had no problems.
CSR260 is offline   Reply
Old 05-02-2010, 05:18 PM   #9
michaellfc95
michaellfc95's Avatar
Quote:
im just worndering iv just got a km how do them bottles work ??
michaellfc95 is offline   Reply
Old 05-02-2010, 09:39 PM   #10
littleguy301
Question here, I run my FG 32 to 1. I hear about all the 25 to 1. Am I going to hurt anything? Easy to figure out, 4oz to a gallon. So in my area alot of the 2 cycle oil comes in 8 oz jugs.
I run just standart 2 cycle oil from the parts store. I havent got into the synthic stuff yet. Though at work they switched us to synthic stuff for our hand saws and that kind of stuff. Ended up blowing up some of the stuff. After that we were told you have to watch some of the fuel and such. Gas will break down within 30 days and with some high test oil could be quicker. Also, being from the Minnesota (USA) area they add some stuff to the fuel for the winter mix, so keep in mind different fuel for the seasons.
littleguy301 is offline   Reply
Old 05-02-2010, 09:52 PM   #11
dwarfy
dwarfy's Avatar
Quote:
Yes mate 40ml of oil per 1 litre of fuel = 25:1 mix
Old 05-02-2010, 09:55 PM   #12
dwarfy
dwarfy's Avatar
Your mix will go 'off' after about 30 days thats why its better to use a 1L mixing bottle if you dont get out too often. That way you can store your fuel and oil separate until you need it.
Old 05-03-2010, 05:20 AM   #13
littleguy301
Good idea Dawrfy, makes sense. Being from the US I still havent gotten the liter thing
I also thought that if I went 32 to 1 I could use it in my weedwacker (40 to 1) or in the winter in my ice auger (25 to 1)
Just some worldy thinking
Old 05-03-2010, 05:32 AM   #14
Timmahh
Timmahh's Avatar
hell im just finishing up gas i bought last November. Literally just filled the tanks with the rest of it 2 days ago. runs just fine. i use Premium 93 here stateside.
__________________
Old 05-03-2010, 07:55 AM   #15
sperera
sperera's Avatar
Yes thats a 25:1 ratio, basically 40ml per litre = 25:1
sperera is offline   Reply
Old 05-03-2010, 11:55 AM   #16
dwarfy
dwarfy's Avatar
The litre thing wont make any difference if you have a mixing bottle. It has a fill line for the gas and then the different level fill lines above that depending on what ratio of mix you want. You simply add the oil to the gas until you reach the desired ratio marker. They have 25:1, 32:1, 40:1 50:1.
Old 05-03-2010, 11:59 AM   #17
dwarfy
dwarfy's Avatar
The mixing bottles would be better if they were 700ml or 1400ml then you would be mixing 1 or 2 full tanks of fuel rather than 1 full tank + less than half of a second tank Just a thought
Old 05-03-2010, 03:40 PM   #18
Timmahh
Timmahh's Avatar
you guys just need to buy Ratio Rite cups with lids.
they have us and meteric measures on it.
__________________
Old 05-03-2010, 04:55 PM   #19
dwarfy
dwarfy's Avatar
Here's the mixing bottle I got. They are a couple of quid of ebay or from model shop.
Old 05-14-2011, 05:11 PM   #20
pacman696
pacman696's Avatar
Send a message via ICQ to pacman696
Quote:
hi guys , when mixing petrol and oil they is one thing i don't get, i got a mixing bottle like the one in the picture ,so if i wanted 50/1 i put less oil in and if i wanted 25/1 i put more in which doesn't add up to me because 50 parts oil must be more than 25 ?,what i have been doing is put a two stroke oil bottle (the one for still saws) and then fill with unleaded and that should be 30/1 ,this makes my head hurt .........................phil
pacman696 is offline   Reply
Old 05-14-2011, 05:39 PM   #21
Sharkey
Sharkey's Avatar
Send a message via MSN to Sharkey
when your mixing fuel its 25 parts gasoline to 1 part oil, not the other way around. think of it this way, 25:1 is half as much gasoline to the same amount of oil as 50:1.
for mixing i picked up a kitchen measuring cup, marked it every 40ml. 40ml of oil for 1l of fuel is 25:1.
Sharkey is offline   Reply
Old 05-17-2011, 04:40 PM   #22
upDUHcreek
I have a ratio rite cup. I can easily mix any ratio I want by filling the oil to the desired ratio line for the amount of gas I'm mixing. They don't have a line for 25 to one, so I just fill it to the 50 to 1 line for a gallon, and I only put in half a gallon of gas. Here's a link to the ratio rite cup at DDM.http://www.davesmotors.com/s.nl/c.88...t.A/id.3350/.f
upDUHcreek is offline   Reply
Old 05-17-2011, 04:48 PM   #23
CSR260
CSR260's Avatar
i just put 160ml of oil with 4 liters in my petrol can! i mix it all in one go.. not had any probs in doing it that way.
Old 05-17-2011, 05:40 PM   #24
Stalle
Junior Member
Stalle's Avatar
Here in Norway we use 5% oil of good quality on tuned rc-engines like Panolin, Klotz or Putoline oil.
In 5 L. gasoline we mix in 2,5 dl good quality oil.
Not tuned engines we use 4% oil .
Stalle is offline   Reply
Post Reply
Share This Post
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
OIl mix ratio for KM buggy. bluesman King Motor Baja 4 04-15-2010 10:34 PM
i thought this might useful gas(petrol) / oil mix chart CAR-KILLER General Large Scale RC 3 01-22-2010 08:37 PM
what oil huntermick General Large Scale RC 8 03-30-2009 02:22 PM
Fuel & Oil Mix RCAholic General Large Scale RC 15 04-22-2007 07:54 PM
Copyright © 2008-2011 LargeScaleForums, All Rights Reserved
Powered by vBulletin®, Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Our Community
Latest Forums Topics
About Large Scale Forums
Need Help?
