Go Back   Large Scale Forums > Large Scale R/C > Large Scale RC Engines and Exhaust
wrong way round clutch?
Discussion in Large Scale RC Engines and Exhaust forum, started by pablo.
Post Reply
Thread Tools
Old 05-06-2010, 10:27 PM   #1
pablo
pablo's Avatar
Trader Feedback: (0)
fitting a new clutch in my sq baja tommorow, heard people are running them the wrong way round to get them to ingage quicker with a 8000rpm red spring,is it just a case of turning the whole clutch round or putting the shoes on back to front, and how do,s that work?????
pablo is offline   Reply
Old 05-06-2010, 10:45 PM   #2
renbar
renbar's Avatar
i did try this on my beetle worked realy well dosnt rev up as much before taking off like it would fitted correct but does work i have changed it back now though as i took engine out for head gasket change put a copper one in and noticed fair bit of clutch dust and marks to show slight ware on the edges ie contact patches so not 100% sure on how long it would last like it
renbar is offline   Reply
Old 05-07-2010, 12:54 AM   #3
sperera
sperera's Avatar
Trader Feedback: (1)
ive heard of allot of people doing this and it seems to work really well, ill be trying it on my beetle when I finish getting the parts I need.
sperera is offline   Reply
Old 05-07-2010, 01:37 AM   #4
kreb
kreb's Avatar
if you want it to engage sooner then why don't you run a 6000 spring? isn't the purpose of putting on a 8000 to rev higher to engage? the guy i bought my baja from had the clutch turned around. i put it back the way it's made to be and i found it works alot better.
kreb is offline   Reply
Old 05-07-2010, 01:39 AM   #5
Bigger the Better
LSF Plus Member
Bigger the Better's Avatar
Trader Feedback: (3)
Mine are backward stock shoes with upgraded springs. Take them apart now and then and wear is minimal. Clutch dust is inevitable with higher engaging springs.
http://www.hpibajaforum.com/forum/sh...0&postcount=19
__________________
If I had a million dollars I'd own them all.
Bigger the Better is offline   Reply
Old 05-07-2010, 01:41 AM   #6
Bigger the Better
LSF Plus Member
Quote:
It was made to run backward. The clutch was designed to run the way its installed.
__________________
Old 05-07-2010, 06:03 PM   #7
pablo
pablo's Avatar
i want it to engage at about 7500rpm so a 6000rpm spring would be no good,
Old 05-08-2010, 04:44 PM   #8
atom3624
atom3624's Avatar
I think you're talkign of 2 things;
1. The engine speed the clutch engages at - 6k or 8k.
2. HOW the clutch engages - this is the 'reverse technique' and I believe shouldn't affect the engine speed. If you've a 6k spring, it'll engage at 6k, etc.
If the engine's 'spooled up', i.e. revving higher, as in the 8k spring then there'll be more power off the line. If the bite is harder with the shoes reversed, I would guess that the 8k spring is better to avoid the engine bogging off the line, BUT I would also guess the wear can be a tad extreme, on the shoes and the clutch bell ... good luck.
Avatar's on form as usual Pablo!!
atom3624 is offline   Reply
Post Reply
Share This Post
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Clutch Casing Removal Bigger the Better Large Scale RC Engines and Exhaust 5 01-23-2012 12:29 PM
Deeside Grand Prix Round 2 - 25/04/10 Hyperpete RC Track and buddy locator 116 05-04-2010 10:30 PM
ultimate clutch benckie Large Scale RC Engines and Exhaust 14 03-23-2010 01:21 AM
Different clutch housings? waqr FG Monster Truck / Beetle 3 07-10-2009 05:45 PM
advice needed on this clutch problem fg dc2 man General Large Scale RC 11 12-29-2008 01:12 PM
Copyright © 2008-2011 LargeScaleForums, All Rights Reserved
Powered by vBulletin®, Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Our Community
Latest Forums Topics
About Large Scale Forums
Need Help?
