Chung Yang versus Zenoah
CSR260
LiVeRpO0L uK :P
Found this on another forum...
Chung Yang versus Zenoah Controversy
We see much controversy on the various RC and Scooter Forums about which is best, the Chung Yang or the Komatsu Zenoah Engines. It is much like the ongoing controversies about many products like Ford/Chevrolet, Colt/Winchester, Fram Baldwin, Sony/Panasonic. We all have our favorites, and it is fun to argue which is best, but in many cases, there is a lot of mis information passed around. Here are a few facts for everyone to think about when passing judgement or making decisions to purchase.
Where are Chung Yang and Zenoah Engines Made?
Zenoah is a Japanese Company, but their engines are not neccessarily made in Japan. They are made in more than one country in Asia, most likely, not Japan. Just like Japanese Cars, and components. Many cars made in USA, and components all over the world. With the Japanese names, everyone thinks they are made in Japan….not so.
Chung Yang is a Taiwanese company. The Chung Yang RC and Scooter engines, at this time are all made under one roof in Taiwan.
Who copied who?
Did Chung Yang copy Zenoah on certain engines? Not necessarily. The engines in the 22.5cc to 30cc category have been manufactured in many countries for light industrial and lawn and garden uses all over the world. They also have been, and currently are being manufactured my many different companies. Lets just say the the broadest application may be “weed wackers”, not R. C. Cars, Boats, Planes etc. They are all clones and no one has been able to remember who made the first engines of this widely used design. They are kind of like “Small Block Chevrolets”. Used and made by many companies for many years.
Number One Seller Chung Yang or Zenoah?
Who sells more engines, Chung Yang or Zenoah? Reliable sources say that Chung Yang sells more engines “Worldwide” than Komatsu Zenoah in the single cylinder 22 to 30cc category. Chung Yang also has more variations and part numbers of these engines than any other company in this market. In this sense, Chung Yang is Number One.
About Quality
Regarding quality comparison. The manufacturing standards of Chung Yang are equal to or in some cases better than Komatsu Zenoah, according to engineering comparisons of manufacturing procedures. One example is the finishing process used on most of the cylinders. This is the process of preparing the cylinders before the chrome plating process, and finishing the chrome plating. The end result is the Chung Yang cylinders have a better finish bore and are more accurately round to promote good ring seal, life and sealing of the rings. While Zenoah uses the bore, hone, plate, final hone process to finish the cylinders, CY uses the bore, Plate, ID grind for much more consistent cylinder wall finish, and measurable cylinder size and roundness. This procedure leaves a cylinder wall finish that is more compatible to the piston rings. We have compared many CY Cylinders to Zenoah cylinders in the past few years, and will most always find the CY cylinders to have closer tolerances of roundness and taper than brand Z.
Manufacturing Processes
We see discussion on chrome plating problems on engines, but we are not getting the full story. Chrome plating of cylinders is a very old procedure for a finish bore on a 2 stroke internal combustion engine. In some applications like Motorcycles & Snowmobiles, it was discontinued back in the 1970′s. It was originally used, as it was the most economical manufacturing process to finish the bore in a cylinder. It remains in the small Chung Yang and Zenoah engines, as it is the most economical way to finish the smaller cylinders.
About Cylinder Chrome Plating Problems
The problem with chrome plated cylinders is that they do not lend them self well to modification of the ports after plating. When you grind the ports in the cylinder to try and improve the performance, you can create a problem. In the exhaust port for example one may raise or widen the exhaust port to move the powerband higher in RPM. In a chrome plated cylinder as it comes from an engine factory, the chrome in the ports extends out of the cylinder bores and into the port a little way. Porting of the cylinders, breaks this wrapping around of the chrome, and leaves a sharp blunt edge, which gives a place for the ring to grab the chrome and start it to peal from the cylinder. If it does not peel at first, it grabs small chrome particles that get spread on the cylinder walls. These small chrome particles are very abrasive, and much harder than steel or aluminum. Eventually, they will destroy the cylinder, rings and piston. This is much more likely to happen in a modified engine. If an engine builder is not experienced on the cause of these problems, they may be improperly porting the cylinders, causing premature engine failure. The engine manufacturer is not the one to blame in this case.
End User caused Engine Failure
There are other factors involved in what causes the failures of the chrome cylinders mentioned above. Oil type, mixture, fuel octane, air filter function and maintenance, and engine rebuilding, just to name a few. Mistakes are often made with either with choice of oil, or mixture ratio, whether intentional or not. An often overlooked factor is “ring life” Piston rings do not last forever. Single ring pistons have a 40% shorter ring life than 2 ring applications, but single rings are chosen for performance reasons. How often should you replace the rings? Probably in 8 hours or less of operation. Calendar time has no bearing on when engines should be rebuilt. You should determine how much fuel has been burned by keeping a log, or track the hours of operation. You can replace the piston and rings to keep the engine fresh and performing at its top level, or run them until the engine and cylinder fails, and blame the engine. The more RPM’s, the higher the compression an engine has, the shorter the ring life. To simplify it, modified engines require more frequent maintenance.
Andy...
I've seen that before ,its wrote by a CY importer.
J
I noticed that as well.
Husqvarna bought Zenoah in 2006. The home office for Husqvarna Zenoah Co., Ltd is in Japan but more then likely they are made in China like most things this day and age. CY is a good engine but Zenoah is top dog.
CY engines are absolutely clones of the Zenoah. I distinctly remember the Zenoah 23cc being used in FG vehicles and on Gopeds long before there ever was a CY engine like that.
c,y is a copy of a zenoah. i,ve run a few c,y 26cc motors and had plating issues on all of them. one brand new motor out of the box lasted 2tanks and the plating give up, i,am not saying all c,ys are like this but they do seem hit or miss. now got a zenoah g23rc and not had a bit of trouble it runs strong even after about 10tanks .
i had 1 zenoha and really liked it, and 3 cy's and really like them. i am currently running a f270 4 bolt cy in my baja and my buddy has the g270 zenoha 4 bolt in his and we see no differences at all besides the names. i've never had a problem with one. i think it all comes down to what you like best or how much hype you believe.
So far all I have had are 4 CY 2 bolt. I have not had any problems with them. At one time CY was having a lot of trouble with the plating but this was suppose to be corrected. I am getting up parts to build my first 4 bolt which will have CY case because I got a new case for $28 with a Zen top end.
Who copied who?
About Quality
Andy...
andy you,ve got a clone motor lad stop trying to convince yea self its as good as zenoah, :lol::lol::lol::lol::lol::lol::lol::lol::lol::lol::lol::lol::lol::lol:
andy you,ve got a clone motor lad stop trying to convince yea self its as good as zenoah :lol::lol::lol::lol::lol::lol::lol::lol:
Pablo, you're making him sound like Dolly the cloned sheep.
i can remember around 1997 a mate of mine had a 5th scale road car with a renault megane shell ,it had a zenoah motor as so did allmost all early largescale c,y just did,nt exist, there are now many clone motors about k,m dzy , and c,y the closest i,ve found to the zenoah is the dzy .
i remember those plating issues Paul,I had two heads with the same problem but none of my Zen's ever had an issue.
J
around last summer i went tru, 2 brand new cy 26,s one lasted about 2 tanks and the replacment about 4 tanks. paul b, had two 29,s go in quick succession, all plating issues, hyperpete on his 3rd cy 26 due to plating and one were the circlip in the piston popped out and destroyed and allmost brand new motor. it seems allmost all the issues are to do with the top end not bottom, i just find the zenoah more stable and the plating seems very good .
Where any of these by chance the alloy removable head engines? I have 4 CY engines and have not had a moments trouble. Yes I do agree Zen is top dog but I do think CY is a decent engine.
I think basically that PERHAPS CY did copy Zenoah, or not, and occasionally the early ones are said to have had a few problems, but it appears there's no difference anyone other than a pro racer will notice ....
Al.
CY has a bigger opening for the cylinder transfer ports on the case and bigger transfer ports in the cylinder. Not saying this is a big deal.
