My HPI 5b SS I have had for about 3 years. The picture was taken right after I put the my CPI pipe on and was still looking good not all beat up like it is now. Here are some of my up grades. I now have my race ported 30.5 with big bore CPI pipe installed.
Team Associated throttle brake
DS1015 servo
201oz
0.108 speed
Turtle Racing
Complete Clutch System (Orange)
Turtle Racing
HD Tranny Plate (Orange)
Threshold
Shock Umbrella Seals with installation tool
Turtle Racing
Heavy Duty Front Chassis Brace
HPI
Front tire molded foams
washers for e clip conversion
Fast Eddie
Wheel Shim Kit
Scorpion Chassis Brace Satin
Pro-Match 6v 4200mAh Hump Receiver Battery
FF Front/Side Windows Smoked
Killer
RC kill switch
Outerwares pull starter cover
PhatDad Fan Cover Saver
Nomadio RX
Quick Release Roll Cage Tubes
Pro-line Bow-Tie Rear Tire Set With Blue Foam Inserts
Hostile Mini MX Tire Soft
Lauterbacher 4 shoe adjustable off road clutch
Outlaw RC upper rear turnbuckles
HPI 87454 Engine mount brace set CF
Team Phat Dad
Front stainless steering turnbuckle set
87549 - HPI HD front aluminum shock mount
CPI Standard Tuned Pipe
Full Force CF brake disc and alloy pads
HPI 87572 alloy heavy duty brake mount
CraftWerks-RC Billet Spur Gear Carrier
Team FastEddy Complete Bearing kit
HPI Heavy Duty 20T Drive Gear 86487
HPI Heavy-Duty Idle Gear 30 Tooth 86485
HPI Heavy Duty Differential Gear 48T:Baja 85481
Skunkworks Titanium Lay shaft
Multiplex Rhino Digi 4 steering servo
On 6 volts
Torque 354 in/oz
Holding power 318 in/oz
Speed 0.10 sec at 60 degree
PA Racing Servo Bracket
TGN CF tank brace
Outerwear air filter cover red
Phat Dad RC Cross-Over Dog bones
Chacal-RC Axle Cup Rings
HPI 187444 CF Rear Chassis
Outerwears Crankcase/Flywheel Cover
Engines I have ready to install. Will be running a CPI Big Bore with them.
30.5 race ported engine ported by ONB assembled by me
GP290 28.5cc race ported by ESP assembled by me
One of the MANY things I like about the CPI is it is well protected.
