I'm doing another. GR340 OBR and tons & tons of high end parts
Dang...If I ordered that much stuff at one time I'd end up back in divorce court haha..key word there "at a time." but anyways if you don't mind me asking what website did you order that beast of an engine RCmax 71? Awesome build BTW
She made her maiden run yesterday minus the RCmax71. I had plans with a group to go to a local closed BMX track about 45 minutes away. Well just happened Saturday evening while running of OBR 340mod truck, I blew a rear diff bearing and took out the ring gear. Not to be left out yesterday. I went to thrashing and was able to get the OBR motor swapped over to the new truck. Go hit the track yesterday. The OBR motor did great on it. ran stock spur with a 20 tooth pinion. And was surprised at how well it pushed the heavier truck around. Can't wait to get the RC motor strapped in tonight
Manny came through and the beast showed yesterday. So exciting to open the box and see that huge pipe on top and the gorgeous motor below. I did manage to get it on the chassis, and fuel hooked to it. Fired it up one time jut to listen to it, and cut it off. Sadly its gone be about 10 days till I can finish it up and start playing. I'm headed out of town for work. ONce I get back, will do kill switch and throttle setup and it will be ready to rip.
Heres another little project I'm working on. There will be (4) light in the stock bumper place, and (4) light on the roof in this bracket. There will be taillights and also under car lighting using (2) small single LED lights sunk into the side guards. All from Killer using there controlled and the 3rd channel on my 4PLS
Sweet Light bar!
Just Kidding! This custom alloy light bar would be the only exception! Man law....
