Yeah its toast,never run that way piston/cylinder its done.It actually dented the piston in against the ring. I cant get the ring off but would this cause the engine not to fire? Because it wont hit a lick
i've used klotz super techniplate for years at 32/1 with zero problrmsi never used lucas 2t anyone else here have experience with this oil?
25:1 is good for these engines.
is that a cy or rovan?What sucks the worst is this engine didnt have 2 gallons thru it. Only had it since April
with the full synthetics 32:1 still spits oil out the ex which is good..i've used klotz super techniplate for years at 32/1 with zero problrms
cy bottom end?Thats a esp full mod 27.2. Cy or rovan i wouldnt be surprised but esp is supposed to be top notch
remove the wrist pin ,check the bearingThats a esp full mod 27.2. Cy or rovan i wouldnt be surprised but esp is supposed to be top notch
No i haven't had time to pull the engine off and flush the case out. I was running in sand at the time it quit on me but idk how sand got thru anywhere as i was running a freshly oiled foam filter with a redneck outer filter and prefilterDid you find out what went through it to cause the damage?
