- Crafers South Australia
If you rig is up do both of the front wheels turn freely when your turn them in the same direction? Yum the grafil guards are nice dam pricy but
Ok what i was asking roll together forward or backwards . you said when you pull off it shakes or something. Are the front brakes binding?
Prolly some play in the bearings. My dbxl did something similar to that. Ended up replacing the hub bearings.
I stuff as much as i can in the rx boxWhat do you guys do with the extra wire from the servos ??? Do you stuff it all in the RX box or zip tie it on the outside ?...
I agree,So as far as I know the RX always sends power and ground out. It's the signal wire that tells everything what to do.
.....pics...or it didn't happen..........
Hey what did you find out with you range issues. And is that salt water?
Kill switch will give interference, u need to add one of thesecool....I musta missed it......and yes....I leave the thin end jus inside the top of the tube to protect it.......highly doubt u got interference from servo/kill switch tbh...
