ive been reading (mostly from Dougstar) that the aluminum poopy isolators are a problem, they absorb heat from the motor (in most cases, some haven't had any issues tho) and the heat transfers to y carb and theres the problem. so yeah i think its that pos rb thing, go back to the stock isolator and try.got it up and running for my first break-in. started up fine after some tuning and ran it for about 25 minutes. when the engine shut off I took off the shell to inspect everything and noticed there was no fuel in the primer bulb and the whole carb was pretty hot and it wouldn't prime. I think something inside the carb melted. I'm going to blame the rb innovations isolator block. back on the bench she goes
