Vinny
Hello, everyone, this is my first post. I am a bit experienced as a 1/8 Nitro XL runner. I just purchased the Rovan 1/5 gas LT 450 . I had no problems the first day with about a 20 min break in time. 1/25 gas / oil .. The second day, i seam to not be able to get the engine to run, or at least it starts, then dies, immediately , either a few seconds of idle or when i give it throttle it stays alive a bit longer, but when i let off the throttle , it dies. Now the only way to keep it alive is half to full throttle then it dies immediately. Keep in mind i have less than 15 min on this engine total, haha... Normally i would be adjusting the low speed needle valves, but it said do not adjust in the break in time. Then i thought to check the spark plug, i cleaned it, it was full of oil really, i cleaned it, repaced it, it ran a little better, but only for the next 3 minutes, then the same thing. It starts easy but dies immediately. The fuel is primed and the settings are unchanged from the factory. I appreciate all advice as a newbie to this style of truck. Thank you. !
