Blackrain Rcmax hybrid build
Incredible build man, came out awesome. Get us some run videos when you run it 👍
Looks good mate, well done. 👍🏻
Top shelf bud👏🏻👏
Amazing results
Thanks guys, hopefully I can get my other builds to look almost as good
The joker design wraps are nice and thick compared to the ones that came with the Vekta. I started to apply them buy using the wet method. Then realize I didn’t even need to do it that way because it was so easy to lay down and remove and re apply.
First start got to run er a little spark plug wire kept jumping of spark plug need to clamp it titer.
But man what a adrenaline rush
https://youtube.com/shorts/-tX87LOYRLU?feature=share
I had a few screws come loose loctite and went back out again. Then had clutch bell come loose figure I will stop there for today.
Today's carnage lost the pin for one side of the brake pads, that cause the gears to lock up made clutch bell bearing come loose and lost a exaust bolt20210905_152821.jpg20210905_190105.jpg20210905_190118.jpg20210905_190140.jpg
All this happened in less than 5 minutes
