Blackrain Rcmax hybrid build
GIF by bjorn
Answered my question😬 Swap a wheel and that will tell you which it is
Will do I’m not missing any screws
I Put the front wheel in the rear and you can see nothing is bent . But the wheel I moved to front is wobbly still it’s eather it’s rim or plastic warped
Yeah I damage the inner part of my hex gen wheels when I snapped my irc drive🤦‍♂️ so I can see the light weight ones bending easily
Are the 3D ones a lot thicker ? Seems like the light weight centers aren’t bad with a small bore if you tumble but might not be strong enough to handle a big bore flip. I can’t imagine if I ever flip the vekta all 4 wheels would be wobbly.
Here's one thing you wanna check too. Make sure you didn't egg out your hubs hole. It can wear your bearings and and links prematurely from the heavy vibration at constant high speeds. This is from a flip and landing on the wheel. The wheel adapter is now garbage, you can't run this against a bearing anymore😬
