Rampage MT gear train questions
Boomkidd
Junior Member
Emerson, New Jersey
So, Ive experienced probably all of the issues that can occur on the MT's. I still love it and plan on upgrading until it doesn't freaking break. At any rate, I usually google search my answers but cant really find much. I was running my fairly new MT yesterday on the last break in tank and couldnt even finish it. I had a grub screw back out on the disc brake area and it caused a lock up. Replaced the screw, continued on. Yesterday a bearing took a dump pn the middle gears. Im going to order quality sealed bearings for this soon...need some $ first! lol
These gears got real hot and I'm running w/o the cover for now. They were literally smoking and I noticed the extreme play in the middle, knew its a bearing right away.
I cant find the Demon 2 speed trans I've read across the board about, only an ebay chinese knock off version. Is that this worth it? See couple negative reviews on it. Or, where the hell do they sell the belt drive conversion kit?? I am dying to change this factory setup out. I assume the gears were smoking hot due to the worn bearing, but man they must get hot in general. Belt drive, or maybe that 2 speed seems like a better route.
Anything I want to address besides the lack of loctite on these? Getting tired of unforeseen problems, am willing to pay whatever to make them not happen. Its one thing if you crash, its another if its breaking from running in a circle on flat concrete (break in.) I even had to re-do the axle pin loctite as it was as if I didn't put it on them (which were all loose, L/R was missing.) I used blue, but this time I slopped it on heavy.
company that made the 2 speed is out of business I believe. I heated up the bearing so much it smoked my backing plate when stock.
I have a stern belt drive on mine. I got it from these guys http://www.ebay.com/usr/www_stern-cnc_de?_trksid=p2060353.m2749.l2754
I don't see any for sale from them but im sure if you reach to them they can hook you up. If you want to see pics of it just look at my build link https://redcatrampageforum.com/threads/ramage-xt-rebuild.13898/
Ah, ok gotcha. Its a shame no one sells these in the US. Im sure they would sell fairly well. Thanks for the advise, I'm going to message this seller now. Thanks man!
If that doesn't work for you ...get a gear plate and layshaft mount from 7075rc it has bigger bearings and much better quality. Id sell ya mine but I want to hang onto in the case a issue ever comes up with my belt drive.
JD
JD
Ah, nice I like oversized bearings definitely. Says "street use only" though... any reason I couldnt run it on dirt, etc?
And what would the 'layshaft' be for? The center diff shaft Im guessing? (Thanks man!) Looking to remedy this so I don't have a future problem is all. If I smash it into something and break it that way, that's a different story lol
  • Solid design keeps rocks and other unwanted items out of car
  • Hollow Design is recommended for street use only
http://www.7075rc.com/lay-shaft-mount/ works for both xt and chimera.
would also order the redcat bearing holders : Redcat Rampage Aluminum Center Diff Mount Part # 710001
I'm running an MT, not an xt. don't think this will fit the MT. Will it?
7075rc parts yes will work the other no there is a redcat specific blue one.
Ah, gotcha. I think Ill get the center diff bearing holders too (blue aluminum.) I think the less flex = less heat.
I didnt realize how much things heat up when running full throttle constantly. Anything else I should maybe change to aluminum? Im not gona right now, just good to know for the future. The plastic arms actually seem to be really good so far anyway, but I have no idea (only did break in so far really...1st engine blew 3 tanks after break in was done- That one was warrantied. Sucks cause they sent a 2 bolt head, I had a 4 bolt.)
I'm not as familiar with the MT as I am with my XT. from my understanding its lil more sturdy compared to mine. All I can say is clean and inspect it after a session. once clean lube and check all bolts and screws for proper tightness. Typical RC maintenance.
If you go on 7075rc site they have limited parts for the MT for some reason. Mainly driveline parts, like sleeved diff drive cups and sleeved cva. The blue aluminum redcat center diff mount is nice along with the brake layshaft mount. Also aluminum redcat servo saver and futaba mount. Otherwise I'm all plastic..
This is my only land RC currently, but I've owned a lot in my time. I'm content w/ one 1//5 scale vehicle for some reason now a days. From my experience on like Traxxas for example is that aluminum arms tend to bend vs the plastic which will flex (or crack of course.) I'm pretty happy w/ the quality of plastic Redcat choose. Things like the bearing holders IMO are important to be metal. After learning how much heat can built up its probably better w/ metal for that reason alone (plastic gets hot and no way it's as rigid as it is cold.) I may do aluminum spindles later on, not sure...would like to get thru break in w/o something failing lol
The 7075rc site has the gear plate listed for Chimera, etc only, but that plate fits the MT I'm 99% sure. If that site did their homework a little better they might make more $$$. Whatevs. I believe the layshaft holder will fit the MT also, but not 100%. Cant find that bearing holder for the layshaft ANYWHERE in metal.
I'm running the Futaba servo mount and using one Hitec servo. Hitech T/B servo too.
I just want to be able to run this w/o something breaking. One thing if you hit a tree at 35 mph, another if it just fails running on flat ground in big circles. I'll upgrade until it doesn't fail from normal use.
If you have the v3 MT the trans gear backing plate is blue aluminum already. I just put in an aluminum brake shaft bearing mount along with the center diff bearing mounts. All are available basically anywhere. Just 1 Hitec steering servo huh? On 6v?
I went and ordered a 7075 backplate anyway. Pretty sure the aluminum stock is different. Says bearings are oversized also. I'm not too sure how the backplate held up after the gears were literally smoking from a bearing wearing out either. I read a few old posts about the steering on here I think. Its ok to run one decently powered servo. Eats less voltage too. doesn't seem different from the stock 2 servos to he honest. Not 1 bit. (This is the V3 MT, 6volts on the servos.) Im also running a Castle BEC pro w/ a 3s lipo. I have a few random lipos not in use so figured why not. Works fantastically. I cant wait until Im done chasing the problems away for good on here lol
You'll have to use Google translate as he doesn't speak English
I have this one on my DR http://www.ebay.com/itm/Belt-Drive-...-HD-Top-Neu-/161517555988?hash=item259b325114
and have just ordered this one
http://www.ebay.com/itm/151015940081?_trksid=p2057872.m2749.l2648&ssPageName=STRK:MEBIDX:IT
ya thats the same guy I got mine from. He understands English if you need to message him. I have the carbon fiber version. you can see it on my build thread. My only pause with this version is it looks like its using the stock plastic gear plate. if you have already smoked the bearings or have gotten very hot you are going to end up with play around there they mount. If you go this route I would also get a aluminum back plate.
JD
JD
I'm going to order the non-CF version then. I did smoke the bearings, but I purchased a 'FastEddy' bearing set for the MT which I received today. How long does it take this guy to ship and how long did it take to receive it on your end? Thanks for the info by the way! Awesome sauce! Im about to order it up in a little bit....
I just messaged the guy for shipping rates. Did you guys have to do this? How much was it about?
JD
This one doesn't come with a plate you just use your original
Initially I ran it with a plastic plate and stock bearings with no probs due to less heat but have upgraded to the al plate and high speed industrial grade rubber sealed bearings just to be sure.
You can get em much cheaper at your local bearing supplier than at RC outlets
When I bought my first one about 2 yrs ago he didn't speak English
Maybe he's found Google?
