Peteolheadz100
Noticed my screws keep getting loose on the exhaust because the stock gasket that comes with the tuned pipe isnt sealing, vibration breaks bolts loose. Any suggestions on using the DDM graphite gaskets or silicone red rtv gasket maker? Using blue loctite they still come loose. The tuned pipe i am using is from the dunerunner not my original one hat comes with the rampage chimera. It has no support bracket at the end to hold it loke the stock one but it sure is bolted tight , don't knlw what i can do......suggestions would be appreciated
