Carnious
Reading the Rules!
- https://t.me/pump_upp
So I bought a brand new pullstart for this used baja 5b I have. I haven’t ever ran it before so I have no idea what’s wrong with it if anything.
But here’s what happened:
-started pretty easy, and ran for a couple seconds at idle and then stalled. Fine
-tried to restart it but after a couple pulls the pull start got jammed with the string pulled all the way out, once loosening the pullstart off of the motor, it automatically retracted.
-tried to start again and got it running, but after like 2 seconds of idle, pull start seemed to “explode” even though string was fully retracted and engine was running.
-pulled the pullstart off to find the string got sucked into the “flywheel?” And I’m assuming that’s what stalled the engine. Also the pullstart spring was all uncoiled under the pullstart.
-so I’ve recoiled the spring and put it all back together. But haven’t ran it again yet.
Any idea what happened and why? I’d like to understand what went wrong here so I don’t do it again.
