1/5 axial yeti hybrid build
Here is a peak at the wheel base. It ended up being 17.5'' and that is ok by me!
I found a bent shock shaft, so I installed some Titanium shafts to all four shocks.
Here is a picture of the build I did that has the stock LST wheel base of 14.2'' next to the new build that has a 17.5'' wheel base.
I started another build. It will look just like the one I just built with the LST2. It will have some different wheels and tires also the aluminum plates will be replaced with carbon fiber. I will also be using a different Motor and esc. The servos will be the same but the BEC will be a Castle 10 amp piece running at 8 volts.
The body will be the same but the rear will have the a spare tire carrier. I have most of the parts in so it should take about a week to build. So it will be very fast paced build.
