- Maryland, USA ??
Correct, on the outside of the tube and the clamp may or may not be needed depending on how tight the fit is.I would assume the tube will go over the outside of the exhaust tube? Use a hose clamp as well?
I bet the fuel line was pinched under the carburetor Ruben is stingy with the fuel line play with the tank They move it around it will pinch the fuel lineI would assume the tube will go over the outside of the exhaust tube? Use a hose clamp as well?
No l wish I was on mine the fuel line is thin black fuel line and too short It was running fine then I was messing around with the gas tank vent because it was not sticking straight up so I pulled it up and when I did it kinked off the fuel line under the carb. The motor would start then lean out and stallWtf mate are you drunk?? ???
TheNo l wish I was on mine the fuel line is thin black fuel line and too short It was running fine then I was messing around with the gas tank vent because it was not sticking straight up so I pulled it up and when I did it kinked off the fuel line under the carb. The motor would start then lean out and stall
Wow yea just read what I said and I might be drunk I was messing with the fuel tank air vent I pulled it up and didn’t realize that it kinked off the fuel line under the carb and it drove me crazy for a couple hoursWtf mate are you drunk?? ???
Yeah fg marder jet pro just a test it made the 36 scream mid to high and made the low end a lot better next week going to get a BartoloneIs that an fg pipe on the x2 chassis ??????
Sorry lt 450?????
