1/5th scale gas signal issue
SonnyMc
Hello all
I just bought full set for the truck, the stuff that came with the truck was cheap crap
I bought this:-
HOBBYMATE Flysky FS-GT3
Dynamite Large Scale Safety Kill Switch that's works fine
new servos
1 60kg steering metal gear
1 35kg for trottle metal gear
brand new 6v battery 1600mah
All leads have ferrite blocks on them just before receiver
So my issue is after I started my rc I started to drive and after afew seconds it losses signal no more the 4-5 meters away the kill switch cut the engine thankfully
I didn't have time today to look into it
Im not sure if I got a brownout or just a simple signal loss
But a brownout? On brand new transmitter/ receiver i just got today
.. so strange
Dynamite kill switches cause alot of issues and the fix is mod killswitch or killer bee if you can find one. The Dynamite has a too sensitive glitch detection. Also 1600 mah is kind of low. You want 3000+ minimum but also better to use a 7.4v lipo 3000+ mah
On the dynamite kill switch there are 2 jumpers you can take off to change the low voltage kill trigger. You can try playing with those. Whats probably happening is the servos draw enough power to get the battery to a low enough voltage to trigger the kill switch
