i got a km 2 speed rev 30.5 and it wont move i think its the spur gear. any one know were i can get a new one please help im new to this
hi thanks for the reply yeah basically i was taking it across the field and it stop moving the clutch bell spins the gears all spin but the drive gear shaft don't but i think theres a one way bearing that sits in the gear mount i think thats gone
http://www.rcmodelz.co.uk/product/King-Motor-rev-2-speed-30.5cc.php
theres pics on there off the 2 speed
stu
theres k,m one way bearings on ebay but whats the point buying another k,m one if they don,t last is there a code on the bearing if so you could get one from a bearing shop theres a few on ebay with fast delivery.
i have had mine out for quite a few runs and the 1 way bearing on mine is still in good shape.
Did the bearing work I need to order one
Was the bearing the same size other than only having one notch on the inside I was gonna modify the second notch at work if there the same size since I ordered it already and order the right one says it won't b here till jan anyways thanks
