hamster huey
Ok I doubt Im the first but if I am I wont be the last! I gave my Ramp an inspection and noticed a broken screw head. I tried to dremel a slot to remove it w/a flat head screwdriver but its stuck. Ok now Im looking for the part # of the part the screw is stuck in. Its the metal shaft that goes through the steering rack. The only thing I can find that might be it is the whole steering rack assembly part number 50012 which is $21! Thats expensive for a broken screw head. But if thats it I guess it does come with 2 of those shafts and a bunch of extra parts but man I just want the shaft! Doe anyone know if 50012 comes with the shaft I need? If not what is the shafts part #? a)Im mad its $21 to fix but its fixed or b)I spend $21 on the rack and it doesn't come with the part I need! Help!
