RoushSport
Hello all. Long time lurker, first time poster. I had a bit of an interesting issue with my Baja. Engine would fire up and idle with no issues. Beyond that, well.....you give it full throttle, and the motor would rev up partially...almost like it was hitting a rev limiter at about 2000 rpm (out of a possible 7000 for reference). The car would move, but very slowly. Tweaking the needles on the carb didn't change the performance at all. If you picked the back end of the car up and took the load off the rear end, wouldn't make a difference. So, I thought it's probably an air leak at the carb. Pulled the carb, replaced the plastic grommet with a metal spacer (Rovan RC), new gaskets, sealed it back up. No change in performance. Next I thought perhaps it's something in the trans or in the diff. From what I understand, there are two bolts behind the spur gear that like to back themselves out, press up against the spur gear, and bind up the whole works. When I opened mine up, everything was as it should be. So, then I thought - perhaps the magneto is off and or moved. Removed the covers to get to the magneto only to find everything was as it should be. At this point, I'm like ok....what the heck. For whatever reason, I spun the flywheel, and I hear a "clink clink" coming from the motor. I'm then thinking - connecting rod, bearing, something is broke. Pull the top of the motor off, and find that the piston has a LOT of carbon on it for only having 3 tanks through it. Additionally, it looks as if there is some kind of copper coating on the rotating assembly - er, was. As you'll notice from the pictures - chunks of it are missing, and flaking off. Additionally, there is a lot of play in the connecting rod where it connects to the crank.
I've ordered a new motor (upgraded to a 36 cc Zenoah, as I hear the CY motors aren't the best in terms of reliability). My question though for you guys - what would have caused this? If it's user error, I'll take it on the chin. I'd like to figure it out though as to not repeat this issue with the new motor. Fuel wise I run 25:1 (which seems like a very high oil content...I'm thinking that might have led to the carbon issues). 93 octane gasoline. Motor was never run lean - I always run a bit rich, intentionally. Motor never ran for more than 15 minutes at a time as I usually had other issues (various parts breaking). So the question again is - could this have been bad fuel that caused this? Running too rich? Perhaps I got a motor made on Friday afternoon or Monday morning and the fit and finish just weren't up to par and it was destined to tear itself apart?
Please let me know your thoughts. Thanks for taking the time to read, and offering any feedback.
