Hi
I have a losi 5t with a engine that I've rebuilt with a obr head,piston, +2mm stroke crank,titanium wrist pin,samba pipe, super bee kill switch and ddm metal gasket set.
It's all back together and I just can't get it started I've got compression, spark and fuel I've also set the coil gap and I've checked the piston is in the right way there no leaks from the engine.
I've try resetting the carb and had the plug out over night just in case it was floored !
Any idea's would be helpful
