30DN SDT - What shock oil do SBR guys run?
JackSDT
New Member
Huddersfield
Hi guys and girls! Wondered what shock oil you guys run in your SBR? I have a 30 Degree North SDT and need to address the overzealous droop on the back, so I'm wondering what shock oil you guys run? And should it be silicone or mineral for this shock?
Thanks in advance
dougstar
The Sheriff⭐
Staff member
PLUS member
Build Thread Contributor
Crafers South Australia 🇦🇺
Thanks in advance
Get a tlr hinge pin bace setup for the rear👍🏼 it allows for anti squat adjustment 👍🏼 put 40wt oil🛢
JackSDT
New Member
Huddersfield
girls! where?
Wishful thinking
Thanks for all the replies!!! Really informative. This is my first largeish scale so it's all a bit alien. I don't know what the standard spring weight is so I'm not sure what spring to go for? The TLR setup sounds good, also trying to find an adjustable camber link set if anyone knows of any? I know these 30DNT trucks are rare but are a very close SBR clone ... hopefully most stuff is interchangeable. Thanks again guys
