5 way micro splitter
Spkey
Junior Member
Scottsdale, AZ
Can this be used with only one steering servo? Is this correct; I plug the steering servo and the on/off switch into the splitter (and the on/off is connected to the battery). I then run the splitter into channel one of the rx and then the throttle servo wire into channel two of rx. And the killer bee kill switch into channel three?
Just want to see I'm doing this correct.
Yes it apears to be correct.Be very careful not to bend the pins on the micro splitter that is not being used.
from the videos I watched on killer rc you plug the battery only into the splitter and the servo and on/off switch directly into the receiver that's how they recommended doing it.
