razorback racing
Hi
What would you guys recommend on a 5t that pushes thru the corners? I have to really come off the trigger and brake to try get this thing thru the corners.
It does look like the outside wheel isn't turning full lock while on the track. But when on the stand epa is set right the dual rate is high. Servo is a 54kg hitech.
Springs on front are standard blue. Rear are gold. 25 rate oil front and rear.
Is it a set up issue? Servo issue? Tyre issue. I'm open for ideas. Could be someone out there that had same issue and what they done to fix it was......
Cheers
Cheers
