Dreggsta
i'm actually gonna go backwards & pose the qestion 1st. i can't look on the redcat site to look at the manual so if someone can answer me, great. i replaced the plastic center diff mounts w/aluminum ones. while putting the drive cups on i found there to be a lil slack that letes the pinion shaft move forward & back a lil. i tried to tap the drive cups on further to take out this slackbut i culdn't. after i got them put in i found a small o-ring. just one. does that go on the other side of the bearing of the center diff mount? if so there'd be 2 by my math. i just see one.
ok, the heads up. both of my diffs (front/rear) were bone dry. there was no oil whatsoever in them. i read on here & other places that they at least had some of that chinese junk in there but nope. dry as a bone. i filled them up a lil over half way with lucas hd oil stabilizer toallow for expansion. stuffs sticky like grease. i love the stuff. anyways, that's horrible what they put my baby gears through what with no lube. that's gear torture.
