After Run, Good Practices
josegarcia8578
San Diego, CA
Hello all,
New to the 1/5th scale! I was wondering what are some good practices for post run? Should the tank be emptied? How about the lines/bulb? Should I drain those if not running for a week? How would I do that, if that's the case?
Or is it ok to leave gas in the system for a week?
I was reading that then engine should not be ran out of gas.
Overall looking for good practices for post run. Thanks in advanced!
Top Dead Center
Colorado
After each run, repack the parachute and a complete engine rebuild.
I dust mine off with an air compressor and wipe off any fuel residue on the tank. Some guys do the mesh mod on the crankcase, I do the Outerwears crank cover and stater cover. Makes it easy to clean with a blast of air.
As far as your concerns about fuel in the lines, don't sweat it unless you are working on your rig in the house. I have weedeaters that sit dormant for seven months and a 20 year old chainsaw that gets used once a year at hunting camp. Each of them are put away with fuel.
Here is my secret to no worries.
Sta-bil
dougstar
Moderator
Staff member
PLUS member
Build Thread Contributor
Crafers South Australia
Sta-bil
I have never drained/purged my fuel in any thing mowers/wakers rc rigs:unsure:(y)
Florida
I’ve left fuel in my 5T’s for months, they crank right up every time....
I easily get 40-50’min runs on just ONE tank, so a GALLON of pre mix gasoline at times can last me 2-3 months.
-I store the fuel in a RED FUEL CAN stored in a A/c control room. Haven’t had any issues ever.
As for cleaning, a good Air compressor does the trick.
If I run thru mud or wet areas i re grease areas with a DRY grease that comes in a spray can. Works great!
I sprayed my 5iveT’s with a 9H ceramic coating, this has made maintenance sooo much easier.
Billp
Wd40 is a degreaser so it will du out your bearings (n) so on other parts just not bearings(y)
I understand that WD40 will also happily displace the lube in the bearings and also leave a nice film on everything to attract dust. People seem to recommend GT85 instead. Don't use it myself, i just blow the dust off and occasionally wash everything down with mucoff them regrease all the booted parts. The only thing I do regularly is check and clean the air filter and wash out the pipe to the carb if needed.
