CyberVet65
When? Do it everytime you run the truck? It looks like I have a Baja 5b sleeve set. I run an Outerwear sleeve and then a coarse foam cover then a fine almost solid foam unit. That is the unit I oiled up really good.
When cleaning. Clean all the units with hot soapy water. Let dry. Then re-oil. I am guessing here. How often? Of course when it looks like it is solid dirt but in between time when it isn't ran in heavy sand or dirt.
How often can the foam units be reused? Not expensive but it would be nice to know how long they will last. How dirty does the Outerwear get before you get a new one? Even when it won't clean up.
When oiling. Make it sopping, dripping wet then squeeze out excess. Or use PJ-1 and spray the oil on. I have K&N's on my bike and truck but they are not foam.
So let's get some input here for us newbies.
Oh yeah, why a velocity stack? I put an angled shred stack for clearance but why a velocity stack.
Pros and cons for the K&N type filters. The same question about the solid can filters like DDM sell. I an thinking more air exposure the better. Does the cans just look good or are the functional?
