Air Filter recommendations - VERY DUSTY
MisterK71
Peoria, AZ
Hey Guys, I have the K&N version of the Losi buggy and it is very apparent that the K&N filter with the Outerwears is not going to do the trick in dust, I mean a lot of dust. I can barely make 1/2 tank before the engine is choked out. What do you guys recommend for these conditions, I live in the desert and everywhere I run is very dusty.
Get the team gonads air filter oil it good (but oil it right) then put an outerwears over that. K&N air filters are actually worse than the stock air filter as far as dusty conditions are concerned.
There is a K&N filter under there with the TGN Red Neck dual stage pre filter which is lightly oiled. I don't live in the desert but have done some running in sand. So far so good. That being said i do mostly pavement and grass but have done some sand.
I have a K&N DBXL and also live in the desert in very dusty conditions. All I have used is the end of some panty hose and an outerwares. I haven’t had any issues as of yet.
