tizdaz
Hi guys,
ok so i tried to fit an alloy diff housing to my DBXL 2.0, i have the FID bracket / Housing & today i bought the diff case, i thought it was just a simple task of swapping the internal gears etc from stock case to the FID one.
I thought all was going well but when i test it by hand by turning the gears, they are not binding smoothly as they should be they are very rough/clunky. So i took it apart, checked everything but all seems in order, so i tried an ATOP case that i also have, same problem!?
are the diff cases for the 1.0 & 2.0 different some how?
also i looked up the diff rebuild kit from losi and the kit comes with small shims for each of the 4 gears inside the case, my stock 2.0 does diff does not have these shims 4 smaller, it only has the 2 larger shims that go over the cup shaft?
I also noticed that the small o-ring on the spur side that sits in the groove does not sit in the FID case 100% flush, even if i use the stock o-ring from stock case, would this be an issue? the shim goes over it & i can pop the pin in place etc but the shim does not sit 100% flat on surface!? but again i tried it also without the shim completely and it was still the same?
The case also comes with gaskets for each side, i tried it with & without the gaskets incase that was causing an issue, but still the same.
Anyway as it is, ive now put the stock diff case back together until i find some answers or solution!
Anyone here had success fitting an alloy diff case, if so do you remember exactly the way you did it? did you have to use small shims on each of the small gears?
This is the case i currently have and also an ATOP one which is also exactly the same.
At the moment im thinking that the case isn't 100% the same dimensions as the 1.0 which these cases are designed for im guessing, so the gears are not 100% aligned inside.
Cheers!
Cheers!
