- Crafers South Australia
LOL you had that coming
I'm giving you about a month once you get it going ,then destruction of some sort .hey hey HEY! Now that's just mean ?????????? got me good there I'll give ya ??
? Yeah, the destruction will be my transmission. Nice one on the brake lines, looks cleaner now without brake lines floating everywere.I'm giving you about a month once you get it going ,then destruction of some sort .
So after looking at the buggy last night for a little bit I said screw it today and re-did all the brake lines . I didn't like all the coiled hose everywhere. So tada. Think I'll probably wrap the brake line near the pipe with a little aluminum tape just to be safe . It's about an 1/8 of an inch . Should beenough but I would rather be safe.
To me it looks bussy as long as it works??I'm giving you about a month once you get it going ,then destruction of some sort .
So after looking at the buggy last night for a little bit I said screw it today and re-did all the brake lines . I didn't like all the coiled hose everywhere. So tada. Think I'll probably wrap the brake line near the pipe with a little aluminum tape just to be safe . It's about an 1/8 of an inch . Should be enough but I would rather be safe.
Are you gonna try DDM black magic gears? What's the plan?Yeah, the destruction will be my transmission
Tr quick diff, fast Eddy bearings, hpi diff gears, possibly IRC or TR diff gear case, blackbone gears, 7075 brake hex, and kraken clipless layshaft. Should b Bulletproof ?Are you gonna try DDM black magic gears? What's the plan?
Blackbone tranny gears handle pretty much everything, peeps run em on rcmax 90cc and such so that won't be a issue. The original HPI made (not sure on the clone ones but I'm risk it) diff gears handle all that power fine as well (somehow), tho the big mofos like 90s and 85s blow them but I'm not gonna be running that much power for it to be a issue.Still even then there will be some shite
Just cant see the gear was made for a 70cc ?
Ok ? for me fast Eddy is just really inexpensive and convinient so I might as well just go there.I'm gonna try some SKF bearings.....cant see the fasteddy ones being any better to honest just cost less
I don't buy their kits because it's a straight robbery. I buy individually, https://www.fasteddybearings.com/metric-bearings/ lucky u have skf nearby!!!!$46 + int. Shipping for me? I have a SKF 10mins drive from my house ?? so I'm just guessing ,but I'm sure I'll get what I need
I wanna see bothSo I finally got the Front disk brakes bled and working. Interesting experience. The key to getting them working right is bleeding the master cylinder. The whole brake system is so small it does make it hard to bleed the system. I still have a little air in the right front brake line so I will probably bleed the brakes one more time. It only takes a about 10 minutes. Most of the time is set up and clean up. Suppose to be a nice weekend this coming weekend so I think it will be play time for the buggy and maybe the boat too.
I wanna see both
+1+1 and we want a run vid??
It's cuase he hit another pole probably ?? an he was too embarrassed to post it cuz he knows he'll get clowned on by me ???Ok so all these months an no run vid?? all we got was 30 second break in? come now coop we want a proper run vid???
Damn right I would, he wouldn't see the end of it, the first crash I's one thing but second??? ?Wouldn't you just lov? get hands on those ?????
