And it begins
dougstar
Likes
1,842
KZN South Africa
Not sure i just assumed so ? :unsure: if they make a case why not? Also seems odd that the hpi spares would not fit and for that reason im thinking there are alternative options:unsure:
Thread starter #144
1Coopgt
Likes
538
Rochester,NY
Not sure i just assumed so ? :unsure: if they make a case why not? Also seems odd that the hpi sapes would not fit and for that reason im thinking there are alternative options:unsure:
I found the TR Diff case saver it called ,comes with a modified by TR hpi diff case with gaskets and stuff . Put it on my wishlist @ DDM and went through and found the rest of the parts for a diff just in case .
Thread starter #151
1Coopgt
Likes
538
Rochester,NY
Now the real work begins . Decided to mount the engine into the chassis . None of the holes lined up . WTF. I had mounted the upper engine mounts to the new engine thinking that would shorten install time . So took both of them off and tried again . Got the the engine mounted with the 3 screws that come through the bottom plate . Cool . Next up the starter side upper mount . Its slotted and it went together and attached to the Upper tranny plate. So the culprit is the Clutch side upper mount . It is too thick in a couple of spots . So tomorrow I'll take the part to work and sand it down in a couple of places and see if it fits . I'm not sure yet but I may need to grind and edge of the tranny plate next to the brake . Not sure yet .
So in the mean time I pulled the rear half of the buggy off to make life a little bit easier to work on . The red square is the issue area .
Z.hb71
Likes
1,265
From rainy, boring, humid, Manvel, Texas
Yeah that area is always a PITA to mount, especially my ALX case (was test fitting it) you have to push it into a wired spot to get it to line up. What I do is leave everything loose and just push in and out and keep my eye on the hole and see if it lines up.
Thread starter #153
1Coopgt
Likes
538
Rochester,NY
After I get the mount fixed I'm wondering how much trouble I'm going to have mounting the Clutch bell and plate . Will probably need to loosen everything up to get those parts in . It wasn't easy getting them in and out before the new tranny and engine . It's ok though I got a really big hammer .:ROFLMAO::ROFLMAO::ROFLMAO:
Thread starter #160
1Coopgt
Likes
538
Rochester,NY
Was the bell carrier touching the bell?:unsure:
No no binding there. Just seems the gears meshing is a little tighter after the Turtle racing parts were installed. Figure everything will wear in or I'll burn up a bearing somewhere in the drive train . I'm hoping for everything wearing in .
Oh it's getting closer . Throttle linkage is next then the 5t side parts . The new pipe will be here tomorrow .
