If so I need pointers
Like my 70cc engine, custom built, and designed personally.as in....
Like ignition, assembly, stuff of that naturepointers for what......
is what I ment..
You need rcmk ignition coil, source coil and ignition rotor Zee, oh and a woodruff key ofcourseLike ignition, assembly, stuff of that nature
Thx, I might be talking a different route on the ignition coil (,not the source but the ignition coil that goes to the plug) tho cuz my timing is not present like ALX is and I'll be running E85 so I think I'll get me a adjustable CDI but everything else I'll get ?You need rcmk ignition coil, source coil and ignition rotor Zee, oh and a woodruff ofcourse
Yeah but the magnet pads on the rotor may not be the same as Alx plus I'm using E85 Wich might need advance or retarding, also it's nice to have that adjustment just in case I wanna try different fuels, also tuning the timing might gimme alittle bit more power cuz I really need that ??Your timing is set by the coil mount position on the case mate
Fair enough, the new alx super engines have adjustable timingYeah but the magnet pads on the rotor may not be the same as Alx plus I'm using E85 Wich might need advance or retarding, also it's nice to have that adjustment just in case I wanna try different fuels, also tuning the timing might gimme alittle bit more power cuz I really need that ??
Ooooo didn't know that ?Fair enough, the new alx super engines have adjustable timing
That would be greatMaby gotta look at that. Would be nice if the just made 2 piece flywheel for adjustment. Loosen a few bolts, give it a turn. Done!
Yes, I have a question, is there a difference between power spark and a CDI?The only option that would be easy for you on ignition is a Power Spark so you can set the timing to your needs and what the engine likes.
