Yeah, that's what I did with mine but when I land nose down on the right front it strips the arm clean inside. Servo's fine but the arm gets stripped out.hamster huey said:I used the largest plastic arm that has 2 sides on it (like on a throttle/brake servo). I sawed off one side, drilled out the very end hole and ran the ball stud through it with lock nut. I think the arm came with the 5745. It is pretty big.
me too; they work fine.hamster huey said:I used the largest plastic arm that has 2 sides on it (like on a throttle/brake servo). I sawed off one side, drilled out the very end hole and ran the ball stud through it with lock nut. I think the arm came with the 5745. It is pretty big.
for some reason thay strip out on me with the 30.5.i just reved a small peace to the alum arm that came with it and 3 thank on it and steel goingaussie said:hi guys
i was just wandering are the plastic servo arms on the hitec 5745 servos strong enough ??
as my blue alloy arms arnt really long enough so i thought i would use the longer plastic arms instead !!
thanks
glen
