Baja 5b Front camber adjustment, how to gain more camber?
Blakesrc
New Member
Hi guys, before I start cutting a stock front upper camber link end... If you want to gain more camber , are there shorter front camber ends available? It appears to get less camber you add spacers behind the standard upper camber rod end but if you wanted more, I don't see a way to adjust that. It looks like my car shows 2 or 3 of the little marks on the rod end as it sits stock.
remove the rod end and fish around in the hole of the a arm with a pick etc to see if any of the spacers are in there fella,
then remove any ya need to get yer desired camber (y)
Hi Spents, thanks for the reply. I have tried but it sure seems like there is nothing in there! On the other hand it seems odd there would be 3 lines showing with no spacers in it to me but who knows, ill give it another try.
yeh have another look fella, the spacers get jammed in there pretty good sometimes,,
check the depth of the hole in the a arm with a small file or something similar,
it will be fairly obvious if theres a spacer or two in there (y),
just had a look at my three bajas and i have one line showing on each of em, i'm pretty sure i have one spacer in each of em as well,
one has km joints and the others two are hpi joints,
thats on one with rpm a arms and two with kraken x2e a arms ,
You were right Spents, I spent a few minutes this morning in the garage with a dental pic and finally got one out of there! I appreciate the help.
