Baja 5b problem. HELP PLEASE!!
mohd777
Dubai
Hello,
I have a problem with my baja 5b, i turn it on and after a while ( 10 seconds ) it turns off by itself , and when i press the throttle there is a sound and it turns off.
and yesterday i put on the outwears for the pullstart and the air filter.
Whats the problem ?
What sort of sound when you press the throttle?
How does the engine sound when it is running? i.e. does it idle normally or is it erratic?
Have you checked the isolator block and carb for correct sealing? i.e. is the isolator block warped so it does not seal right on the engine or are all the gaskets worn? very cheap to fix and common problem is the carb and isolator block gaskets want replacing.
If you have a picture of the area around the carb/iso block it may help or even a sound clip of the engine.
