Baja in alloy
noddy_2121
Hi all,
What will the baja be like with a full alloy upgrade? So far i have only got rear hub carriers in alloy, but i loke the look of alloy and im sure it will be much stronger overall with alloy than plastic.
Any suggestions?
cheers
you ll gain weight. alot of guys do a full alloy build, but i prefer to leave some items stock for break points. i run stock hubs F and R, Stock Shock towers in rear, and shock tower supports in front. this allows the plastic parts to fail opposed to bending the alloy. also the parts that i have kept stock, are easy to change parts.
The alloy adds way to much weight in my opinion. You
need plastic parts for a weak point. Plus a 23cc is going
to have a real workout with that kind of weight. In alot of
cases there is no need to have an alloy part except for
the BLING factor.
JUST MY TWO CENTS>
iv just bought some alloy rear hubs for my baja 5b and they feel so much more solid than the stock ones. I took a hit off a marder a few weeks ago and it just smashed my stock rear hub clean off!
I want my baja to be like a tank! Not too worried about loosing a few mph, il just have to upgrade the engine.
How i look at it is real cars don't have any plastic parts so i don't want my toy car to either :)
You should be selective when you choose the alloy parts. Like Tim said, you need some parts to give in order to save more expensive parts.
The hubs are a good idea, not only for durability, but performance as well.
Also, look into lower rear arms, i noticed that they are worth it.
Chris
Where are you located? Have you looked at a Saturn lately? There is a reason they guarantee them not to dent. :laugh:
Alloy is good in the areas that you tend to have constant failures. The rest of the areas I keep plastic.
