Baja Motor Mount
Paul Williams
Hi guys, recently i bought myself i Baja SBK and i built it and waiting for the motor but there seems to be no way to attatch the motor to the chassis only the upper motor plate. I have allways know for the motors to be bolted down to the chassis. Please anyone help if possible. Thank you.Motor mount.jpg
For the Flux, the motor only attaches to the motor plate on the side (not to the slots you are showing). Those slots are actually for a plastic cover which you'll attach at the very end of the build.
Just follow the manual - I finished this build recently and other than some part numbers which were wrong, everything goes together as you would expect.
Oh right i get it now thanks for your help im releaved now haha thanks again. :)
Hi guys, recently i bought myself i Baja SBK and i built it and waiting for the motor but there seems to be no way to attatch the motor to the chassis only the upper motor plate. I have allways know for the motors to be bolted down to the chassis. Please anyone help if possible. Thank you.View attachment 87183
Believe ,me the engine will be bolted to the chassey.
this is one of the hardest fifth scales to work on.
i have had 5 of theese at different times. just finished building one of the self build kits.
Mine is electric (Flux)
And as Smirkracing has said all it needs to do is to connect the electric motor to the rear upper chassis plate. Thanks for your help.
Im getting the hang of it now i appreciate all of your help.
This guy did a complete build on YT. I used these of videos a couple of times when I was stuck (go this homepage and search for Baja and you'll get an entire series of videos covering each major section).
He does a great job of capturing on video almost every part of the build for the Flux version.
