baja pod mod
GLYNSAVAGE
SE LONDON
ripped off one of my side pods at the weekend and bent up the plastic skid pan so got to thinking how can i improve this weak point in the baja?,and came up with this:
its the origanal plastis skid pan with some ally plate silliconed on and then the side pods bolted?sandwiched between the two
the bits of foam are the tank insert out of an fg which should stop stones doing this again :
still a couple of fins left. :D
Timmahh
Bajastafarian Madnes
PLUS member
Michigan
ouchie. the outerwears on the PS wont stop that. those rocks got in the back of the motor most likely in the large openings behind the flywheel.
T
Bigger the Better
LSF Plus Member
PLUS member
Minnesota
T
Agree... Been there done that.:(
Nice mods the filter material could also come from the Cobra Ridge Venting for roofing or the Scrub pad material used in floor scrubbing. Only way to keep the gravel from entering the engine is to cover the back holes too, only bad thought is something entering in the shroud around the exhaust or carb and not being able to get out.
