Paulrcul8r
New Member
- Reaction score
- 0
Can anyone give me some advice on my Baja, it is pulling to the right even with steering trim adjustment all the way to the left
I think it is just the characteristics of a rear wheel drive buggy ,mine does it also!..Can anyone give me some advice on my Baja, it is pulling to the right even with steering trim adjustment all the way to the left
Bro check rig to make sure nothings bent then check tires as well then go from there check rear as well speed can turn 1 degree off to 50% off real fastA good place to start:
1: Remove your servo arm from the servo.
2: Power your rig on and set your steering trim to neutral.
3: Line your wheels up and re-attach your servo arm.
4: Adjust trim as needed to drive a straight line.
