Baja steering probtlem
ANGRYEVO8
Perth Australia
Hi guys i have an issue with my steering on my Comp baja and need some advice. When i steer the wheels in either direction the inside wheel goes right to the stops but the outside wheel doesn't get anywhere neat as much turning angle. I have tried adjusting the turnbuckles and moving them along the steering arm but when i do that i will gain more lock on the outside wheel but lose it on the inside wheel, or my toe goes out the window.
Has anyone else got this problem or is this just an issue the cars have.
post a photo showing the position of your ball joints on the steering arm and servo saver so we can see if there maybe better positions to try.
Hi guys i have taken three photos the first one shows how the car is set up with no steering input. The second shows a left turn and how much difference there is between the right and left wheel in terms of angle. The third shows how much further the right wheel can go when the turnbuckle is disconnected. Please note that in photos two and three the servo saver is in the same position of full left turn.
Guys could someone please put up a photo of their steering setup also showing the distance between the plastic side guards and the plastic ball and socket. Mine seem to be catching a little.
Did you read my link I posted for you mate?
That's how it's ment to be.
Brad.
