- Thread starter
- #21
Yeah I will be mate just taking my time.lookin forward to this build miles, are ya gonna do a super detailed build thread ?
Yeah I’ll be using blue Paul and all bolts will be torqued down to 5Nm minimum with locktite. As you say I may use red on the engine and just use the soldering iron to loosen them.if it was me i'd use blue on the symsteer miles, if ya use red then remember yer probably gonna have to apply some heat to get the fecker apart if ya needs to ,
depends on amount of vibration from the engine as well
moving steering parts i'd use lithium miles,Yeah I’ll be using blue Paul and all bolts will be torqued down to 5Nm minimum with locktite. As you say I may use red on the engine and just use the soldering iron to loosen them.
What would you use to lubricate the moving steering parts? Red n Tacky or Lithuim?
Thanks Paul, it’s always nice to have someone confirm your thoughts.moving steering parts i'd use lithium miles,
red n tacky will drag a bit i bet, wont need much lube anyways
It’s a bit tight Doug for a free moving part.Dose it even need lube?
There is worse to come.so much for that id put that one on the rc40 baja then
Cheers Paul mate, I know it will overall and be stronger for it because of the materials.having been there, done that with trying to save weight/build something superlite i feel for ya mile,
its so hard trying to get the weight down on a baja,
stick with it matey, and don't get too brassed off, yer gonna gain weight in certain areas but the weight will reduce overall
