Bartolone Racing V2 Velocity Stack mod for choke lever
one2boost
Maui, HI
Bartolone Racing V2 Velocity Stack mod for choke lever. There was another thread about another subject but someone posted they used a teflon/plastic spacer to have the clearance for the choke lever. I didn't want to hijack that thread.
I just used a dremel and a carbide bit to notch the v-stack to gain enough clearance for the choke lever. I marked a centerline on the v-stack in relation to the choke shaft. Just grind the notch a little at a time and test fit it on the carb with lever. One could also use the small sanding drum roll to give it a better finish at the end.
