trxrdr17
Hi All,
When I got my DBXL-E 2.0, the hobby shop sold me (2) Power Hobby 4S 5200mAH 50C batteries. I later bough a set of Power Hobby 4S 8000mAH 100C batteries. I ran 3-4 times and then upgraded the pinion to a 15T and also added motor fans. When I ran them today for the first time, the 5200mAH barely lasted 10 mins before cutoff kicked in. The batteries were hot and may have been puffed, however it was very hard to tell if they were pulled due to the hard case they're in... I ran the 8000mAH batteries and they were much warmer than I wanted when I was done.
When I got home, I plugged all 4 into my Venom charger to return them to storage voltage. 1 battery won't charge and gives a low voltage error. Here are the cell readings from both 5200mAH batteries:
Took charge - 2.88, 2.75, 2.62, 3.11
Won't charge - 2.59, 2.54, 2.69, 2.70
Not sure what I did wrong? I haven't touched the cutoff voltage level programmed in the ESC, it's still set to medium (the middle setting). I no expert with Lipo batteries, but I know they aren't supposed to get too warm or puffy. If I have a junk battery, I'm not sure I want to go with Power Hobby again.
