Pedal2themedal
- Reaction score
- 0
Working on my build a bit, and I am debating between using the belt drive or the 2 speed Demon tranny. When all is said and done, my engine will be right around 8-9 HP so it has to be STOUT.
Any suggestions?
Also, was looking at my center diff (the giant ring and pinion) and the alignment seems to be off. The pinion acts like it is a few cm's short. Because of this the gear mesh is very loose. There is no way that it would work with my engine I have coming. Have any of you had this issue? Can it just be shimmed up to mesh with the ring better?
Any suggestions?
